Hello, I am trying to get GNUARM4 working with uVision3 but with little success. I have followed the instructions here: http://www.keil.com/support/docs/3127.htm which direct me to set the following values: GNU-Tool-Prefix: arm-elf- Cygnus Folder: C:\Program Files\GNUARM\ However, I still get the error message: --- Error: can't execute 'arm-elf-gcc' GNUARM was downloaded from this website: http://gnuarm.com/ The two versions I have tried are: bu-2.16.1_gcc-4.0.1-c-c++_nl-1.13.0_gi-6.1.exe and bu-2.15_gcc-3.4.3-c-c++-java_nl-1.12.0_gi-6.1.exe Any help would be greatly appreciated. Scott
I can use the same settings without a problem. Can you please generate a batch file and post it's content: - Options for Target->Output->Create Batch File - Project->Rebuild all Target file. Can you try to build the \ARM\GNU\Boards\Keil\MCB2100\Blinky Example?
An excellent tool for debugging this type of problem is found at the following URL http://www.sysinternals.com/Utilities/Filemon.html This will allow you to see what and where exactly uv3 is looking for the executable. It provides a log of the disk activity. You will even be able to see the searching for the Cygwin DLLs - for example - if that is what is causing the problem.
I have the same problem: I try to build \ARM\GNU\Boards\Keil\MCB2100\Blinky the output window shows: Build target 'MCB2100 Flash' assembling Startup.s... Target not created Then i generated the batch file. It looks like this: SET PATH=C:\Arquivos de programas\GNUARM\Bin;C:\Arquivos de programas\GNUARM\Arm-Tools\Bin\ SET GCCINC=BIN\INC\Philips\;BIN\INC\ SET GCCLIB=BIN\LIB SET CPU_TYPE=LPC2124 SET CPU_VENDOR=Philips SET UV2_TARGET=MCB2100 Flash SET CPU_CLOCK=0x00000000 arm-elf-as @.\flash\startup._ia What should I do next??
You should move your GCC to a folder without spaces.
