I am reading in I2C protocol, which fills up a USB_TX_Buffer. I have that buffer in the watch window and can see the values I want filling it up, but when I to transmit it out on the UART TX pin on the F320 all I get is a steady Voltage high signal. The second bit of the code is the UART init. Anyone have any ideas?
else if (TI0) // A TX is complete, handle TX states, inside UART interrupt { TI0 = 0; // Clear transmit flag UART_TX_NDX = 0; // Reset index init_UART(); SCON0 = 0x00; while (!FLAG_UART_TXDONE) ////switch (NEXT_TX_STATE) { ////case STATE_SEND: if (UART_TX_NDX < SMBus_UART0_RX_NDX) { SBUF0 = USB_TX_Buffer[UART_TX_NDX++]; } if (UART_TX_NDX == SMBus_UART0_RX_NDX) { FLAG_UART_TXDONE = 1; } ////break; ////default: ////break; } } void init_UART(void) { TMOD |= 0x20; // Timer 1 8-bitcounter/timer w auto-reload CKCON = 0x08; // Timer 1 uses the system clock/1 TH1 = 0x30; // Timer 1 Equation17.1 BaudRate for 57600 & 24Mhz ////TL1 = 0x30; // Low bytes of Timer 1 TR1 = 1; // Timer 1 on S0MODE = 0; // 8 bit UART with Variable Baud Rate RI0 = 0; // Recieve Flag (Clear by software) ES0 = 1; // Enable UART interrupts SCON0 |= 0x10; // Enable receive (REN0 is 1) ////PS0 = 1; // Set to high priority }
init_UART(); In the ISR????????????? Erik
Yea, that was supposed to be commented out. The init_UART is called in the main program below. Still same probelm tho, still steady high voltage on P0.4 (UART TX)
void main() { char SampleCount = 0; unsigned int i; PCA0MD &= ~0x40; // Disable Watchdog timer P0 = 0x00; P0MDOUT = 0x00; // Sets P0 to open drain ////P0MDOUT |= 0x10; P2 = 0x04; P2MDIN =0xFF; P2MDOUT = 0x00; EA = 1; // Enable global interrupts USB_Init(VendorID, ProductID, ManuStr, ProdStr, SeriStr, MaxPower, PwAttributes, bcdDevice); Oscillator_Init(); // Setup SYSCLK to 24 MHz init_UART(); USB_Int_Enable(); // USB API generates interrupts SMBUS_Selection = P1^5; SPI_Selection = P1^6; UART_Selection = P1^7; // JS Init_Device(); if (SMBUS_Selection == 0) { init_Timer2(200); // 200 Hz sample rate init_Timer3(25); // SMBus SDA timeout after 25 ms init_SMBus_Master((long)400000); // 400 kHz SCK frequency // Reset the bus SMBus_ResetBus(); // Enable SMBus interrupt EIE1 |= 0x01; // Start device reading flag_DEVICE_READING = 0; // SMBus_QueryAllDevices(); while (1) { if (REG0CN & 0x40) // If USB connected send thru USB { while (flag_Timer2Running); start_Timer2(); // Wait if the device is not reading while (!flag_DEVICE_READING); // Read each device in the device address list for (i = 0; i < SMBus_DevListNDX; i++) { // Begin a read SMBus_ReadSlave(SMBus_DevAddrList[i]); // Wait for current read to finish while (flag_MODULEBUSY); } // Send data up USB if (SMBus_TotalRXNDX > 0) { flag_USB_TX_DONE = 0; // Clear USB TX flag Block_Write(&USB_TX_Buffer, SMBus_TotalRXNDX); // Send up buffer SMBus_TotalRXNDX = 0; // Clear count // Wait for write to finish while(!flag_USB_TX_DONE && flag_DEVICE_READING); } } else // No USB connection, Send thru UART { flag_DEVICE_READING = 1; init_SMBus_Master((long)400000); // 400 kHz SCK frequency while (flag_MODULEBUSY); // Issue general call to query devices on bus SMBus_QueryAllDevices(); for (i = 0; i < SMBus_DevListNDX; i++) { // Begin a read SMBus_ReadSlave(SMBus_DevAddrList[i]); // Wait for current read to finish while (flag_MODULEBUSY); } } } } else if (SPI_Selection == 0) { // SPI_Master_Init(400000); // 400 kHz SPI_Master_Init(100000); // 100 kHz while (1) { while (flag_SPI_slaveselected) { // Start transfer flag_SPI_RX_Done = 0; // Clear flag while(!flag_SPI_RX_Done) SPI0DAT = 0x00; flag_USB_TX_DONE = 0; Block_Write(&USB_TX_Buffer, USB_TX_Buffer[4]); // Send up buffer an169 while(!flag_USB_TX_DONE); } } } else if (UART_Selection == 0) { while (1) { flag_UART0_RX_Done = 0; ////while (!flag_UART0_RX_Done) ////SBUF0 = 0x00; //// EIE1 &= ~0x02; // Disable USB0 interrupt flag_USB_TX_DONE = 0; Block_Write(&USB_TX_Buffer, USB_TX_Buffer[4]); // Send up buffer an169 while(!flag_USB_TX_DONE); //// EIE1 |= 0x02; // Enable USB0 interrupt } } }
When i run the code on the processor the voltage stays steady around 3.3 volts on the transmit pin and the RX pin is around 6 volts! Is that right?
When I change the TIO part of the UART interrupt to the following code below to just output a steady value there is no probelm. Only when I try to put the USB_TX_Buffer[UART_TX_NDX++] into the SBUF0 it stops working. I put the EIEI1 &= ~0x02 to dissable the USB interrupt thinking maybe the code was going for an adventure there, but didnt help.
else if (TI0) // A TX is complete, handle TX states ----------------------- { TI0 = 0; // Clear transmit flag UART_TX_NDX = 0; // Reset index ////SCON0 = 0x00; ////TR1 = 1; while (!FLAG_UART_TXDONE) ////switch (NEXT_TX_STATE) { EIE1 &= ~0x02; // Disable USB0 interrupt ////case STATE_SEND: if (UART_TX_NDX < SMBus_UART0_RX_NDX) { ////SBUF0 = USB_TX_Buffer[UART_TX_NDX++]; SBUF0 = 0xFF; } ////if (UART_TX_NDX == SMBus_UART0_RX_NDX) ////{ //// FLAG_UART_TXDONE = 1; //// } ////break; ////default: ////break; }
