give an example of a51 file for blinking LEDS. How to write in assembly code (filename.a51) to blink the LEDS using LPC932 board.
I suppose you could always just use the .lst file generated from compiling the blinky.c example. It shouldn't be that hard to rewrite the C version in assembler if that's what you want.
Take a look in your Keil\C51\EXAMPLES\ASM\ folder - there's an example of an assembler program there, and adapting it to flash a LED shouldn't keep you from the bar for too long... You can find the full 8051 Instruction Set in Chapter 2 of the so-called "bible" for the 8051: http://www.semiconductors.philips.com/acrobat/various/80C51_FAM_PROG_GUIDE_1.pdf
Thanks for giving direction . I have that fill with me . i have written the program in the pdf file u have given me. But sorry it is not working could u please write a simple program for me for blinking the LEDS in A51 assembly code. I will be thankful to u .
u have given me. But sorry it is not working could u please When you specifically address your question to "micro" why do you post in a forum instead of e-mailing him. Erik
See http://www.keil.com/forum/docs/thread7041.asp
