ASC0
Hi
How can I determine the value of BG(ASCx_BG) and FDV? If I intend to follow the specifications:
Input clock: fasc=40MHz
FDE=1
BRS=0
Baudrate=115.2kbps
Die Jong
  • The reason I ask about the value of FDV and BG because someone used the values such as
    ASC0_FDV = 0x00EC;
    ASC0_BG = 0x0004;
    I could not get the answer by using the forumla:
    baud rate = (FDV/512)*(fsys/(16*(BG+1))
    I know there is a table 18-6 that tell me the value of FDV and BG should 76 and 4 respectively.
    Can anyone please tell how to get these below values from ?
    ASC0_FDV = 0x00EC;
    ASC0_BG = 0x0004
    Die Jong
  • Here is my code...
      ///  Configuration of the ASC0 Baudrate Generator:
      ///  - fractional divider as prescaler for baud rate timer is used
      ASC0_FDV       =  0x00EC;      // load ASC0 fractional divider register
      ///  - required baud rate = 115.200 kbaud
      ///  - real baud rate     = 115.234 kbaud
      ///  - deviation          = 0.030 %
      ASC0_BG        =  0x0004;      // load ASC0 baud rate time reload register
      ///  Configuration of the ASC0 Operation Mode:
      ///  - 8-bit data asychronous operation with one stop bit
      ///  - receiver is enabled
      ///  - fractional divider is enabled
      ASC0_CON       =  0x0811;      // load ASC0 control register
    So
    If I use the forumla:
    Baud rate = (FDV/512)*(fsys/(16*(BG+1)))
    Now I apply the value of ASC0_FDV=0x00EC (236) in the FDV, 115.2kbps in baud rate and 40MHz in fsys resepctively. BG would be about 9.
    Then why is the ASC1_BG is 0x0004??
    Have I made any error in my calculation or miss out any paramount equation?
    Die Jong
  • Hi,
    maybe its the fact that there can be more than one solution to your formula that is confusing you ?
    You can use either
    FDV = 0x76 && BG = 0x04
    or
    FDV = 0xEC && BG = 0x09
    Depends on the Precision you need.
  • Thank you for pointing it out....
    I found that 20MHz is used as fsys instead of 40MHz....
    So that the values of ASC1_FDV and ASC1_BG are correct.
    By the way, Happy new year guys :)
    Die Jong
