Hi, I 'd like to use Atmel AT90S2313 in my application, but the device is not supported in the Keil uV2 compiler. Would it be possible to use the uV2, please some one assist me. Thank you very much Kurnia Brahmana
1) the chip is an AVR type, where do you see that Keil support AVR 2) why do you want to use a chip that is tated as "not recommended for new design" Erik
As Erik says, the AT90S2313 is an AVR - and Keil don't make compilers for AVRs "Would it be possible to use the uV2" Yes, it would be possible to use UV2 simply as an editor and project manager, and use another vendor's compiler, linker, etc - but this would be pointless. There are plenty of Toolsets available for the AVR - some free, some low-cost, and some high-cost. See: http://www.avrfreaks.net/index.php?module=FreaksTools&func=viewTools
