how can i convert int value into float in 8051 assebly?i want to find the average of 12 int valuse which may be float so i want the result in float?
how can i convert int value into float in 8051 assebly? Basically, you don't. Because the 8051 has no notion whatsoever of what a floating-point number is. You can't convert to something that doesn't exist in the world view of the CPU. Nor do you really need to. The average of 12 integers is a fraction. Not all fractions have to be represented as floating-point numbers. Most, indeed, shouldn't. Learn about fixed-point arithmetics.
"how can i convert int value into float in 8051 assebly" You would have to either write your own complete floating-point library, or buy one. If you really must use floating-point, Why not just use 'C' which has floating-point built-in? (though not in the free eval version) One the other hand, as Hans-Bernhard said, why not use fixed-point instead? Work smarter, not harder!
my problem is that when i want to get value like 5.8 ,instead of it i got 5 ,is there any method to convert 5 into float?
"my problem is that when i want to get value like 5.8" Just pre-multiply everything by, say, ten; so that the answer becomes 58 - presto! no floating point required. This is the principle of fixed-point maths. Prescaling by powers of ten is convenient if you need to display the results in a decimal format; powers of two would be quicker (as they can be implemented with a simple shift). "is there any method to convert 5 into float?" I've already answered that one!
http://stevehollasch.com/cgindex/coding/ieeefloat.html
