Temp Meter
I am working on a design using the on-chip temperature sensor:
Displays the room temperature in a LCD
and lights an array of six led's blinking to
form a christmas tree.
Need assistance in C or assembler ...
  • the on-chip temperature sensor
    The '51 does not have any such thing, you need to specify the actual derivative.
    does that translate to "send me the code?". Sounds like that when nothing else is said.
  • ; Temp_2.ASM
    ; This program configures the on-chip temperature sensor with the ADC.
    ; An external 18.432MHz crystal is used as the system clock source.
    ; The ADC is configured for left-justified mode, GAIN = 2, using Timer3 overflows
    ; as the start-of-conversion source.
    ; Timer3 is configured in auto-reload mode to overflow every 10ms.
    ; The ADC conversion complete interrupt handler reads the ADC value and compares it
    ; Tmp = (about 25 degrees C), stored in ROOMCODE.
    ; If the measured Tmp is below this value, the LED is turned off.
    ; If the measured value is above ROOMCODE, the LED is turned on.
    ; The LED switch point value - ROOMCODE.
    ; EQUATES
    $INCLUDE (C8051F000.inc)
    LED EQU P1.6 ;LED on target board ('1' is LED ON)
    SYSCLK EQU 18432 ;SYSCLK frequency in kHz
    TC_10ms EQU (SYSCLK / 12) * 10 ;number of timer counts in 10ms
    ROOMCODE EQU 0xb3f0 ;left-justified ADC value for 25 degrees C.
    ; VARIABLES
    MYDATA SEGMENT DATA ; declare DATA segment
    RSEG MYDATA ; select DATA segment
    ; ADC data variables
    TEMPCODE: DS 2 ; holding register for temp code (16-bit)
    ; stored MSB-first
    ; STACK
    STACK SEGMENT IDATA ; declare STACK segment
    RSEG STACK
    DS 80h ; reserve 128 bytes for stack
    ; MACRO DEFINITIONS
    ; RESET AND INTERRUPT VECTOR TABLE
    CSEG AT 0
    ljmp Main
    org 7bh
    ljmp ADC0_ISR ; ADC0 end of conversion interrupt
  • ; MAIN PROGRAM CODE
    Temp_2 SEGMENT CODE ; declare CODE segment
    RSEG Temp_2 ; select CODE segment
    USING 0 ; using register bank 0
    Main:
    mov WDTCN, #0deh ; disable watchdog timer
    mov WDTCN, #0adh
    mov SP, #STACK-1 ; init stack pointer
    mov OSCXCN, #67h ; enable external crystal oscillator at 18.432MHz
    clr A ; wait at least 1ms
    djnz acc, $ ; wait 512us
    osc_wait: ; poll for XTLVLD-->1
    mov a, OSCXCN
    jnb acc.7, osc_wait
    orl OSCICN, #08h ; select external oscillator as
    ; system clock source
    orl OSCXCN, #80h ; enable missing clock detector
    mov XBR2, #40h ; Enable crossbar and weak pull-ups
    orl PRT1CF, #40h ; enable P1.6 (LED on target board) as push-pull
    acall ADC0_Init ; initialize ADC0 and temp sensor
    acall Timer3_Init ; initialize Timer3
    acall Timer3_Start ; enable Timer3
    acall ADC0_Enable ; enable ADC
    setb EA ; enable global interrupts
    sjmp $ ; spin forever
    ; MAIN SUBROUTINES;
    ; INTERRUPT VECTORS
    ; ADC0_ISR
    ; ISR is activated on the completion of an ADC sample.
    ; When event occurs, the ADC value is copied to the holding variable TEMPCODE, and is
    ; compared with the code for 25 degrees C.
    ; If the temperature is above 25 degrees C, the LED is turned on.
    ; If the temperature is below 25 degrees C, the LED is turned off.
    ; There is no correction for self-heating.
    ADC0_ISR:
    push PSW ; preserve registers
    push acc
    clr ADCINT ; clear ADC0 interrupt flag
    mov TEMPCODE, ADC0H ; copy MSB of ADC0 result into
    ; TEMPCODE
    mov TEMPCODE+1, ADC0L ; copy LSB of ADC result into
    ; TEMPCODE
    ; compare TEMPCODE with value expected for 25 degrees C
    ; if (TEMPCODE - ROOMDEG) < 0, then turn LED off, otherwise, turn it on.
    ; calculate TEMPCODE - ROOMREG and store in TEMPCODE (16-bit subtract)
    clr C
    mov a, TEMPCODE+1 ; subtract LSBs
    subb a, #LOW(ROOMCODE)
    mov TEMPCODE+1, a ; store new LSB
    mov a, TEMPCODE ; subtract MSBs (and carry)
    subb a, #HIGH(ROOMCODE)
    mov TEMPCODE,a ; store new MSB
    setb LED ; turn LED on.
    jnc ADC0_ISR_END ; exit if subtract result was positive,
    clr LED ; otherwise, turn LED off then exit
    ADC0_ISR_END:
    pop acc
    pop PSW
    reti
  • ; SUBROUTINES
    ; Timer3_Init
    ; Routine initializes Timer3 in 16-bit auto-reload mode to overflow
    ; at 100Hz using SYSCLK/12 as its time base. Exits with Timer3
    ; stopped and Timer3 interrupts disabled.
    Timer3_Init:
    mov TMR3CN, #00h ; stop Timer3, clear TF3, use
    ; SYSCLK/12 as timebase
    mov TMR3RLH, #HIGH(-TC_10ms); init reload values
    mov TMR3RLL, #LOW(-TC_10ms)
    mov TMR3H, #0ffh ; set to auto-reload immediately
    mov TMR3L, #0ffh
    anl EIE2, #NOT(01h) ; disable Timer3 interrupts
    ret
    ; TIMER3_Start
    ; This routine starts Timer3
    Timer3_Start:
    orl TMR3CN, #04h ; set TR3
    ret
    ; Initialize ADC0 for left-justified mode monitoring the
    ; on-chip temp sensor at a gain of '2'. Leaves ADC in disabled state.
    ADC0_Init:
    clr ADCEN ; disable ADC
    mov REF0CN, #07h ; enable temp sensor, bias
    ; generator, and output
    ; buffer
    mov AMX0SL, #0fh ; select TEMP sensor as ADC0
    ; input
    mov ADC0CF, #80h ; set SAR clock to SYSCLK/16
    orl ADC0CF, #01h ; PGA Gain = 2
    mov ADC0CN, #45h ; ADC disabled, low power
    ; track mode, ADC0 conversions
    ; initiated by overflow on
    ; Timer3, left-justified data
    ret
    ; This routine enables the ADC and ADC interrupts.
    ADC0_Enable:
    setb ADCEN ; enable ADC
    orl EIE2, #02h ; enable ADC EOC interrupt
    ret;
    ; End of file.
    END
