about .COD files
hi
i want to prevent liker to genarte .cod file
how to do that.
is there is any directive for that,like we have directive for genrating .cod file (CODE).
i m using misrovision 3 IDE.
also i m not able to genrate .SRC file from the .C source file.
i m getting Error like this
custom translating test.src...
--- User Command terminated, Exit-Code = 1
Target not created
how to solve this error.
pls do reply
thanks
vidya
  • Yes, you can switch off generating Linker Code Listing file .COD
    Uncheck the following check box:
    Options for Target -> Listing -> Linker Code Listing
    Why do you need a .SRC file? You may use extended inline assembly feature of CA compiler instead?
