SMBus and LTC1380 MUX State Machine Design Problem
I am having problems with this state machine on setting up an LTC1380 Mux Device.
It is really hard to track progress of this state machine without disrupting the bus for logging or stepping through the code/ISR.
Has anyone any comments on why this is failing?
Greatly appreciated in-advance.
void initializeSMBus0(void)
BUSY = 0;
ENSMB = 1;
STA = 0;
STO = 0;
SI = 1;
AA = 1;
SMBFTE = 0;
SMBTOE = 0;
int getAllADCMuxDataFromInternalBank0ADCs(void){
volatile int i;
volatile int j;
volatile int retVal;
retVal = NO_ADC_ERROR;
for (i=0;i<NUMBER_SMBUS_MUX_CHANNELS; i++)
theSMBusMuxChannel = i;
for (j=0;j<NUMBER_SMBUS_MUX_BANKS; j++)
theSMBusMuxBank = j;
DISABLE_INTERRUPT_INTERNAL_UART0;
ENABLE_INTERRUPT_SMBUS;
setupSMBusMuxBankAndChannel();
DISABLE_INTERRUPT_SMBUS;
ENABLE_INTERRUPT_INTERNAL_UART0;
AMX0SL = j; // Internal ADC 0 MUX CHANNEL SELECTION.
AD0INT = 0; // Set complete conversion interrupt flag to conversion not completed.
AD0BUSY = 1; // Initiates ADC0 conversion if AD0STM1-0 = 00b (set in init above).
while(AD0BUSY !=0){} // Wait for conversion to complete.
printf ("B[%i] CH[%i] ",j,i);
printf (" 0x%2x ",ADC0H);
printf ("0x%2x ",ADC0L);
printf("SMBusCntr=%d",SMBusCntr++);
printf("\r\n");
return (retVal);
int setupSMBusMuxBankAndChannel(void){
SMBusDevicesClass = EXTERNAL_SMB_MUXS;
ENSMB = 0; // Reset Bus.
ENSMB = 1;
SI = 0;
delayTime(DELAY_WAIT_EXTERNAL_SMBUS_RESET_BUS);
// Hangs Here on second iteration...???
//while (BUSY == SMBUS_BUSY_IS_BUSY){} // If SMBus is busy then stay here.
//?? an113 PG 25
// BUSY = 0; // App note say to do this.
// Start the setting of the Mux
STO = 0;
STA = 1;
return(retVal);
void SMBus_ISR(void) interrupt 7 using 2
switch (SMBusDevicesClass){
// Linear SMBus device LTC1380
case EXTERNAL_SMB_MUXS:
switch(SMB0STA & 0xF8)
case 0x08: // Start condition transmitted.
switch(theSMBusMuxBank){
case 0: theSMBusMuxCommand = SMBUS_MUX_BANK_0; // 0x90
break;
case 1: theSMBusMuxCommand = SMBUS_MUX_BANK_1; // 0x92
break;
case 2: theSMBusMuxCommand = SMBUS_MUX_BANK_2; // 0x94
break;
default:;
SMB0DAT = theSMBusMuxCommand;
STA = 0;
break;
case 0x18: // ACK from slave was received for valid address.
STO = 0;
switch(theSMBusMuxChannel)
case DAQ_CHANNEL_OVEN1 : theSMBusMuxCommand = 0x08; // 0x08 | 0x00
break;
case DAQ_CHANNEL_BLOWER : theSMBusMuxCommand = 0x09; // 0x08 | 0x01
break;
default:;
break;
case 0x20: // NACK was received from Slave. Retry Address.
STO = 1; // Set Stop Mode
STA = 1; // Set Start Master Mode.
break;
break;
break;
default:;
break;
case 0x28: // Data was sent to slave and received ACK back.
STO = 0; // Done with the single channel data send to slave MUX.
break;
case 0x30: // Data was sent to slave and received NACK back.
// Retry data send to slave MUX.
// NOTE: NEED COUNTER HERE FOR NOT GETTING STUCK IN AN INFINATE LOOP.
// And a global flag for indicating that this happened.
break;
break;
default:;
// Maybe need to reboot (book offers opinion.)
break;
case 0x38: // Arbitration lost.
// Save Current data.
// Nothing to do here for Master to Slave MUX devices.
// Well maybe keep last value logged in sampling averaging.???
break;
case 0x00: // Bus Error (Illegal Stop Start)
STO = 1; // Reset Bus.
break;
case 0xF8: // IDLE - Does not set Interrupt;
// NOTE: Can poll to send START.
break;
default:;
break;
case EXTERNAL_SMB_RTC:
break;
default:;
SI = 0; // Clear SMBus Interrupt.
  • I won't bother looking at the code since you didn't bother using the <pre>/</pre> tags to maintain its formatting.
    That aside, if you are having trouble with tracking the state machine, maybe monitoring the bus itself would be helpful.
    http://www.usbee.com has some inexpensive I2C/SMBUS monitoring intruments.
  • OK, formatting is in...
    Only using SiLabs F021 MCU as master to 2 slave MUX devices.
    #define DISABLE_INTERRUPT_INTERNAL_UART0 IE = IE & 0xFE;    // Bit 0 is UART 0 Interrupt.
    #define ENABLE_INTERRUPT_INTERNAL_UART0  IE = IE | 0x01;
    #define DISABLE_INTERRUPT_SMBUS EIP1 = EIP1 & 0xFD;
    #define ENABLE_INTERRUPT_SMBUS  EIP1 = EIP1 | 0x02;
    	BUSY = 0;
    	ENSMB = 1;
    	STA = 0;
    	STO = 0;
    	SI = 1;
    	AA = 1;
    	SMBFTE = 0;
    	SMBTOE = 0;
    	volatile int i;
    	volatile int j;
    			printf (	" 0x%2x ",ADC0H);
    			printf("	\r\n");
    	return (retVal);
    	ENSMB = 1;
    	SI = 0;
    //?? an113 PG 25
    	STO = 0;
    	STA = 1;
    	return(retVal);
    				break;
    				break;
    				break;
    			default:;
    		STA = 0;
    		break;
    		STO = 0;
    						break;
    						break;
    			default:;
    		break;
    				break;
    				break;
    				break;
    			default:;
    		break;
    		break;
    						break;
    						break;
    			default:;
    		break;
    		break;
    		break;
    		break;
    	default:;
            break;
    			break;
       default:;
  • "Has anyone any comments on why this is failing?"
    You haven't actually stated in what way you think it's failing!
  • "It is really hard to track progress of this state machine without disrupting the bus for logging or stepping through the code/ISR."
    That's true of just about any real-time debugging!
    Have you tried just doing a "manual" code walk-through?
    You can do this as a pen-and-paper exercise, just following the code as you apply the appropriate events...
    You could do a similar thing in the simulator...
    Do you have a design in state charts, diagrams, or whatever? Have you tried walking through that to ensure that the design is correct?
    To trace real-time execution, you could write event & state info to some area of RAM, then examine that after a suitable period...
  • One thing that looks a little fishy, is that you enable the SMBus interrupt and call setupSMBusMuxBankAndChannel() which towards its end "Start[s] the setting of the Mux" (presumably all the action happens in the ISR), then immediately disable the SMBus interrupt upon returning. How can the ISR ever have a chance to do its work?
  • I thought the ISR would remain in effect until the state machine finishes in the ISR?
  • Or should I place a while(!done) loop wrapping the switch state machine?
  • Ok, I've changed some things and implemented a history buffer. The history buffer for thr entries are always 0x08 - bus start.??? Why not progressing?
    #include <stdio.h>
    #include "c8051F020.h"
    #include "debug.h"
    #include "error.h"
    #include "errorCodesForSMBus.h"
    #include "externalSMBus.h"
    #include "externalSMBusADCMuxs.h"
    #include "sio.h"
    #include "systemGlobals.h"
    #include "utilityRoutines.h"
    		case 0: theSMBusMuxBankSelectCommand = SMBUS_MUX_BANK_0; // 0x90
    			break;
    		case 1: theSMBusMuxBankSelectCommand = SMBUS_MUX_BANK_1; // 0x92
    			break;
    		case 2: theSMBusMuxBankSelectCommand = SMBUS_MUX_BANK_2; // 0x94
    				break;
    	    default:;
              case DAQ_CHANNEL_OVEN1          : theSMBusMuxChannelSelectCommand = 0x08;  // 0x08 | 0x00
                                                break;
              case DAQ_CHANNEL_BLOWER         : theSMBusMuxChannelSelectCommand = 0x09;  // 0x08 | 0x01
                                                break;
              default:;
        resetSMBus0();  //    ENSMB = 0; ENSMB = 1;
        SI = 0;
       STO = 0;
       STA = 1;
       SMBusDone = FALSE;
       while (SMBusDone == FALSE){}
       return(retVal);
    			       // MASTER TRANSMITTER
                                  #if (DEBUG_SMBUS_USE_HISTORY_BUFFER == 1)
                                     SMBusStateHistoryBuffer[SMBusHistoryLogIndex++] = 0x08;
                                     if (SMBusHistoryLogIndex == 50) while(1){}
                                  #endif
                                  SMB0DAT = theSMBusMuxBankSelectCommand;
    			                  STA = 0;
    			                  break;
                                      SMBusStateHistoryBuffer[SMBusHistoryLogIndex++] = 0x18;
                                  #endif
       			                  SMB0DAT = theSMBusMuxChannelSelectCommand;
                                  STO = 0;
    			                  break;
                                      SMBusStateHistoryBuffer[SMBusHistoryLogIndex++] = 0x20;
                                  #endif
    			                  break;
                                     SMBusStateHistoryBuffer[SMBusHistoryLogIndex++] = 0x28;
                                  #endif
    //			                  STO = 0;  // Done with the single channel data send to slave MUX.
    			                  STO = 1;  // Done with the single channel data send to slave MUX.
                                  BUSY = 0; // FROM an113 SiLabs
                                  SMBusDone = TRUE;
    			                  break;
                                  #endif
    			                  break;
                                     SMBusStateHistoryBuffer[SMBusHistoryLogIndex++] = 0x38;
                                  #endif
    			                  break;
    			       // ALL.
                                      SMBusStateHistoryBuffer[SMBusHistoryLogIndex++] = 0x00;
                                  #endif
    			                  break;
                                      SMBusStateHistoryBuffer[SMBusHistoryLogIndex++] = 0xF8;
                                  #endif
    			                  break;
    			       // STATUS CODE NOT IDENTIFIED.
    			       default:;
                 break;
                    break;
    	   default:;
  • You clearly use a derivative with SMbus hardware interface. Such derivatives are NOT identical.
  • Got it working.
    Anyway, SiLabs LTC1380 is the devices.
    What I last posted I just needed a SI=0; at the end of the ISR. Was very close. I was entering an infinite loop.
    The mux's are working correctly now.
