Hallo, Everytime when I want to programm my µVision 3 shut down after few minutes. What's the problem? Thanks, Stefan
Everytime when I want to programm my µVision 3 shut down after few minutes. Could you give a little more details ? What happens ? Are there any error messages ? Is there anything specific you do before it "shuts down" ? It could be anything. Maybe a hardware defect (memory ?) ?
Everytime when I want open Components,Environment and Books / Folders/Extensions my computer have the error: The instruction at "0x004b93b8" referenced memory at 0x00000000c. The memory could not be "read". What can i do?
Everytime when I want open Components,Environment and Books / Folders/Extensions my computer have the error: The instruction at "0x004b93b8" referenced memory at 0x00000000c. The memory could not be "read". Thanks. That contains a whole lot more information than the original posting. What can i do? 1. Run a memory test on your computer (use ctramtst or memtest86) to exclude faulty memory. 2. Do you have any on-access virus protection running ? Disable it temporarily and see if the error persists.
That means, that my PC was the problem. If I will us an other PC, the program works?
That means, that my PC was the problem. No, it means that the hardware in your PC might be what's causing the problem. Did you run the memory test yet ? It might also be some other software that is running on your PC (anti-virus software sometimes causes these errors, for example). If I will us an other PC, the program works? Maybe. Depends on what the problem actually was.
