Hello: Here is my problem: After I compile a file with no errors or warnings, I get this message when I try to debug it: *** error 56: cant open file I'm using uVision2 V2.40a A month ago I had no problem doing that. But I didn't change the settings. So I don't know what can it be. Any suggestions? Regards, Mark
hi I had the same problem and I could repair it , with the option in target of use on-chip rom try it.
Thanks Strangely, I could use debug without using that option. But if it happens I'll keep it in mind. Regards, Mark
