Movx command in Keil
Hello all,
I'm using Keil uVision2 Version 7.05, and everything seems to be OK. However, there is one thing I don't quite understand, thus I'm posting here asking for your ideas/opinions.
When I run "Hello" example in Keil\Example directory and I found something that puzzled me. The assembly code Keil generated in Disamsembly window as well as in list file always have MOVX command eventhough I don't use external ram at all. I did set memory model to small and I only use IDATA but it still does the same. I even use disamsembler to translate the hex file Keil generated back to assembly source and still get the same result. Can someone spend some times explain this for me? Any inputs would be greatly appreciated. Have a nice weekend.
Best Regards,
T.L
