Deleting .OBJs versus "Build All"
We're still getting some odd results from the C51 toolchain from time to time. We get different builds if we manually delete all .OBJs than if we tell uVision to "build all". You'd think that would replace all the .OBJs.
We get different code generated when the load is rebuilt with the two methods. And in the "build all" case, the loads often do not run correctly, while the manually deleted version does. I can't imagine why there's a difference in the two cases; you'd think "build all" would rebuild everything, and start just by deleting the existing .obj.
A couple of examples of the same section of code from the two different build methods:
version 1:
                R      MOV     DPTR,#entry
                       MOV     A,R6
                       MOVX    @DPTR,A
                       INC     DPTR
                       MOV     A,R7
                       MOVX    @DPTR,A
                                           ; SOURCE LINE # 189
                                           ; SOURCE LINE # 191
                 R     MOV     queues,#08H
                                           ; SOURCE LINE # 192
                 R     MOV     queues+01H,#08H
                                           ; SOURCE LINE # 194
                 R     MOV     DPTR,#entry
                       MOVX    A,@DPTR
                       MOV     R6,A
                       INC     DPTR
                       MOVX    A,@DPTR
                       ADD     A,#05H
                       MOV     DPL,A
version 2:
                       MOV     R3,AR7
                       MOV     R2,AR6
                                           ; SOURCE LINE # 189
                                           ; SOURCE LINE # 191
                 R     MOV     queues,#08H
                                           ; SOURCE LINE # 192
                                           ; SOURCE LINE # 194
                       MOV     A,R3
                       ADD     A,#05H
                       MOV     DPL,A
version 1:
         R     MOV     DPTR,#link
                       MOV     A,R7
                       MOVX    @DPTR,A
                       INC     DPTR
                       MOV     A,R4
                       MOVX    @DPTR,A
                       INC     DPTR
                       MOV     A,R5
                       MOVX    @DPTR,A
                                           ; SOURCE LINE # 552
version 2:
                R     MOV     DPTR,#igmp
                       MOV     A,R4
                       MOVX    @DPTR,A
                       INC     DPTR
                       MOV     A,R5
                       MOVX    @DPTR,A
;---- Variable 'link' assigned to Register 'R3' ----
                       MOV     R3,AR7
This code happens to be from the 7.10 compiler, but we see the same thing with 7.50. Optimizations level 9 or 11, register coloring enabled. Load is bank switched, using LX51.
Any clues as to what is going on? And is there a way to guarantee reliable results from the build short of manually cleaning up the last build every time?
  • This seems quite strange. Have you tried looking at the .cod file?
    Could you post a bit more code showing the preamble to the existing snippets, preferably with source included?
  • "We get different builds if we manually delete all .OBJs than if we tell uVision to 'build all' ... register coloring enabled"
    This has caused me similar problems before.
    IIRC, the "register colouring" file was not deleted by 'Build All' - so it could affect the results.
    So, when you say, "delete all .OBJs" do you just delete *.obj, or do you clear the entire "objects" folder - which would include the "register colouring" file?
  • Are you using any/all of __DATE__, __TIME__, __FILE__, __LINE__, etc in your code?
    I have occasionally seen bizarre side-effects as a result of these; eg
    When the time goes from 9:59:59 to 10:00:00, the length of the string changes.
    Using __LINE__, even just adding/removing a comment can affect the generated code, as the source line numbers will change!
    Strings are generally stored in CODE space, so these kinds of things can affect the usage of code space...
    This may be entirely irrelevant to your situation, but might be something to think about if all else fails...
  • Thanks for the suggestions.
    We clear out the old objects with a "del *.obj", so anything else hiding in that directory will still be around.
    Which file holds register coloring information?
    We do have a __DATE__ __TIME__ in one module which, well, displays the date and time of the build on a CLI over a UART. That file is marked as "always build" in uVision.
    Most of the differences look very much like optimization to me. Some differences just omit repeated loading of R3 with 1 for a generic pointer to xdata, for example, or have some DPTR accesses where a temp appears to spill out of the register set.
    The most disturbing thing is that the loads are functionally different. That is, we get bugs or the code hangs with build all, but if we delete the obj's and rebuild, it works fine. Same source.
  • "Which file holds register coloring information?"
    <project_name>.reg
  • The information in the global register coloring file is a result of several compiler/linker passes over the project and usually includes several different compiles of certain files.
    Failure to delete the .REG file could account for the problems you are seeing.
    Jon
  • Jon;
    The point being, why does "Build All" not clear the *.REG file?
    Bradford
  • The point being, why does "Build All" not clear the *.REG file?
    Probably because that would render them pointless. The real question would be: does register colouring really gain you enough that simply turning it off to work around this issue is a non-option?
  • I assume we're actually talking about the .orc file rather than a .reg file?
    http://www.keil.com/support/man/docs/uv3/uv3_b_filetypes.htm
    http://www.keil.com/support/docs/1774.htm
    This is one of those projects that's been growing for a couple of years. Every little bit of space savings helps, since there is a large installed base of hardware with a fixed memory size, and we're close to the limit. But it's not necessarily a project killer. Enabling register coloration seems to save perhaps 50 bytes out of 89K of code in this particular project. We'll see if turning off the optimization makes the problem go away.
    The deltas on the .lst files indicate a fair amount of unneeded register reloading when the .orc file is missing. "Unneeded", of course, in the opinion of the optimizer, which may be overly optimistic, or just plain misinformed by some error in our configuration. This would explain why some of the builds crash, as the optimizer removes code that really is needed to establish some parameter in a register.
    I'm not really clear on how to determine if this really is a compiler bug, or some sort of error in our bank configuration and assignments that somehow confuses the optimization..
    Thanks for all the hints and suggestions so far.
  • Has there been any improvement on this problem in v8.00?
    It's still driving us nuts with 7.50. Everyone's adopted the habit of blowing away the object directory before a build; otherwise, there's about a 10% chance the executable is corrupt.
