Hi, I've a bit banging I2C implementation that uses port pins. Now I'd like to use it in several projects. But the projects have their I2C pins on different locations :-( I think there is no way to pass the address of a bit (port pin) to a function. As there is no indirect addressing in bit instructions it wouldn't help much anyway. So the only solution I have found so far is to define the I2C pins for every project and compile the module again. This is a thing I'd like to avoid. So I thought of importing an 'EXTRN bit(scl)' and declare the bit in another C-Module. So far all I've got are linker errors. Any idea how to do this? TIA Bernhard 'Gustl' Bauer
Does any of this help: http://www.keil.com/forum/docs/thread714.asp "all I've got are linker errors" Might help if you shared precisely what Linker errors they were... (Cut-and-paste the entire message text - don't re-type).
Hi, thanks for your quick response. Your link was very intresting, but didn't help much. Linker reports actually a warning: *** WARNING L2: REFERENCE MADE TO UNRESOLVED EXTERNAL SYMBOL: SDAB In a C file I had: "sbit SDAB = P2^3;" I tried the combination: EXTRN NUMBER(SDAB) unsigned char idata SDAB _at_ 0xA3; It results in linker error: *** ERROR L121: IMPROPER FIXUP So I asume that the linker recognize somehow that SDAB must be inside bdata and doesn't allow greater addresses than 127. Bernhard 'Gustl' Bauer
"SDAB must be inside bdata" No - it's not! You've defined it as a bit within P2. I don't know off-hand the A51 syntax for that, but you need to get it right! I think A51 understands C51 header files, doesn't it?
In a C file I had: "sbit SDAB = P2^3;" I tried the combination: EXTRN NUMBER(SDAB) you need to include the sbit..., you can not reference it externally. Thus the sbit... should be in a .h file included in both modules. Erik
I think A51 understands C51 header files, doesn't it? Thats news for me. I just tried it. It fails on C syntax. But it seams to work on preprozessor commands.
Of what i use, it "understands" all except struct and such. I use it extensively. Even conditional assembly can be contrilled by #define. So where I used to have a .h and a .inc for C and assembly, I now have a .h with the mutually digestable stuff and a .h with the structs which the assembly does not use anyhow. This is a much safer operation than the old .h and .inc. Erik
and a .h with the structs which the assembly does not use anyhow And you could reasonably easily do away with that secondary file, too: just put (an equivalent of)
#if defined(__C51__) || defined(__CX51__) #endif
