I'm working with a 32K microcontroller using external code banking. The external bank area is in address 0x8000- 0xFFFF and I have 16 banks of 32K. If I configure a function in bank 0 I see that its code is in address 0x8000, but if I configure this function in bank 1 I see that code is in 0x18000. I think if the size of the banks is 32K, if I choose Bank 1 for this function I should see the code of this fcn. in address 0x10000.
"I'm working with a 32K microcontroller using external code banking. The external bank area is in address 0x8000- 0xFFFF and I have 16 banks of 32K." 16 Banks of 32K is a total of 512K. Maybe you have a good reason, but it does seem odd to choose a processor with only 32K of code space when you know that you're going to need an extra 512K!! :-0 http://www.keil.com/forum/docs/thread5739.asp There was a spate of people asking about cramming huge amounts of code into small 8051's recently: http://www.keil.com/forum/docs/thread7324.asp http://www.keil.com/forum/docs/thread7519.asp http://www.keil.com/forum/docs/thread7445.asp Anyhow, you didn't actually ask a question! What is your problem?
I think if the size of the banks is 32K, if I choose Bank 1 for this function I should see the code of this fcn. in address 0x10000. You probably need to refer to the description of how the code memory is mapped in your system. I would guess> that the internal code memory is always mapped to the addresses 0x..0000 to 0x..7FFF, regardless of the selected bank. The external memory thus is mapped to 0xYZ8000 - 0xYZFFFF, with YZ being the number of the bank.
The size of my external flash memory banks is 32K. I have 16 banks of 32K. My question is: Can the micro switch the bank per 32K bank? Or the only possible size to switch a bank is 64K?
Being more explicit: The size of the external memory banks can be different to 64K ?
"The size of the external memory banks can be different to 64K ?" I think you need to look-up Keil's description of their code banking in the Manuals! Switching 64K means that you are switching the entire CODE address space of the 8051! Keil's code banking requires a common area that is always present - so, effectively, you cannot have 64K banks.
Keil's code banking requires a common area that is always present The Keil tools also support the 64KB "full bank" scheme, where the entire address space is switched. This requires replicating common code (constants, interrupt handlers) in each bank, and so is a little less memory-efficient than the 32KB + 32KB window scheme.
There was a spate of people asking about cramming huge amounts of code into small 8051's recently known as "PC thinking" or "having no idea whatsoever" Erik
"The Keil tools also support the 64KB "full bank" scheme, where the entire address space is switched. This requires replicating common code (constants, interrupt handlers) in each bank" True - I did over-simplify. But this still has the same effect of a single common bank and two "switched" banks. ie, the two 64K "full banks" only give you a total of 3x32K CODE space - not 2x64K
True enough -- unless you can shrink the size of the common bank. I suppose the main use for the 64KB scheme is highly segmented code that can run in distinct "phases", or perhaps code that just can't stand the bank switch thunk penalty. The original point is well taken, though -- if you expect to need 512KB of code, you should probably start asking whether the classic 8051 is really the right processor architecture.
I heard lot of theories for code banking but yet dont know how to practically implement it using 8051 hardware & keil software? My code banking concept is not clear, can anyone pls explain me in very simple & prctical terms aided with clear hardware schematic & software code examples? I want to interface 512KB of non-volatile Data RAM / EEPROM / Flash to Philips P89C668 (8051 core). Does anyone know good links to the same? What extra coding logic is required with Keil C code? -Meghal.
Meghal Vasa, As this is not specifically related to the foregoing discussion, you should start a new Thread for your topic. You are actually asking about Data banking, not code banking - they are somewhat difrerent! If you want to refer to this or other existing Threads, do so by posting a link in your new thread (just copy & paste from your browser's address bar).
