What is the Memory Pool Header
Where is [should be] an instance of Memory Pool Header created (I mean this struct that is referenced in memory allocation library files --malloc.c, free.c, realloc.c init_mem.c):
struct __mp__  {                   /* memory pool */
  struct __mp__   *next;           /* single-linked list */
  unsigned int      len;           /* length of following block */
  • The heap is located at the address passed in as the first parameter to init_mempool(). See the source for init_mem.c (usually located in the .../lib directory of your Keil installation).
    The headers come before the client-usable memory blocks.
