Hello!! I'm building a watt hour metter using a CS5460A. I am using the EOUT and EDIR pins in Normal Format. But a I have problems with the value of Pulse Rate Register. I calculated this value using the data sheet's formula, but when I take measures of energy of a load, the values do not agree with the real ones. Help me please.
This forum is for discussion of Keil tools. You should direct questions about the operation of a particular chip to that chip's manufacturer.
