Question about keypad?
I had post a same message before.
Timer0 scan a 3*4's keypad with 10mS Interval,and var Key will be changed to a value when button be pressed or 0xff when all buttons be unprssed.Every button include 4 letters,like,one button has '1','a','b','c'and another has '2','d','e','f'. How i can realize these as a keypad on mobilephone,as press button '1' once Key == '1',and double press it quickly Key == 'a',etc?can you give me some source code for exsample?
Best regards,
Nanntiangumo
  • Sounds like a State Machine would be an ideal approach to this problem.
  • "I had post a same message before."
    and have you been thinking about it during the intervening time?
    What ideas have you come up with?
  • The first thinking as following :
    void Timer0(void) interrupt 1
    		if (bKeyDwF == 1 && bKeyRdyF == 1)	 		//Twice scan finished
    			cCount ++;
    			if (KeyTemp0 == KeyTemp1)		 		// scan result being same would changed value to var Key
                    Key = KeyTemp0;
    	            else Key = 0xff;			 		// Or Key would be changed to NUll (0xff)
    			bKeyFree = 0;
                bKeyDwF = 0;
                bKeyRdyF = 0;
            if (bKeyDwF == 1 && bKeyRdyF == 0)	 		//Scanning a Key the second time
                KeyTemp1 = Scan();
                bKeyRdyF = 1;
            if (bKeyDwF == 0 && bKeyRdyF == 0)	 		//Scanning a Key the first time
                KeyTemp0 = Scan();
                bKeyDwF = 1;
    		if (Key == 0xff )
    			bFF = 1;	    						//Set unpressed Flag;
    		if (Key != ETB && Key != ESC &&	Key != SPR && Key != PDW && Key != 0xff)
    			if (bLetterNum == 0)					//Resolve Keys in Letter mode
    				if (Key != cKeyTemp)   				//A new Key pressed;
    					cKeyTemp = Key;	   				// Key value be taken to  buf;
    					cHarKey = KBChar[Key][0];  		//Return the key 's first value ;
    					cCount = 0;
    				else 				 				//The same Key pressed ;
    						if(bFF == 1)  				//The same Key unpressed ;
    							cCount = 0;
    							cHarKey = KBChar[Key][cKBCount];  			// Return the Key 's another value
    							if (cKBCount < 3)
    								cKBCount ++;
    							else
    									cKBCount = 0;
    							bFF = 0;									//Clear unpressed Flag;
    			else if (bLetterNum == 1)	 								//Resolve Keys in Number mode
    						cKeyTemp = Key;
    						cHarKey = KBChar[Key][0];  						// Return the Key 's first value ;
    						cCount = 0;
    					else 			   									// The same Key pressed ;
    							if (bFF == 1) 								// The same Key unpressed;
    								cCount = 0;
    								if (Key == 0 || Key == 9)				//Resolve mutil_value Key
    									if (Key == 0 )
    										if (cKBCount != 0)
    											cHarKey = '-';	  			//Return the NEG symbol;
    										else
    											cHarKey = '0';
    									else if (Key == 9)
    											if (cKBCount != 0)
    												cHarKey = '.';	  		// Return the value point
    											else
    													cHarKey = '9';
    									if (cKBCount < 1)			 		// The mutil_value Key counter;
    										cKBCount ++;
    									else
    											cKBCount = 0;
    								else
    										cHarKey = KBChar[Key][0];  		//Not mutil_value Key,return the Key 's first
    									}							   		//value immediately;
    								bFF = 0;  // Clear unpressed flag;
    		 	if (cCount == 8)  											//The same Key pressed 8 times
    				bValKey = 1;  											// Set the valid Key 's flag,CHARKEY would be main() taken to resolve;
  • basic keypad code (assuping you drive columns and read rows.
    1) feed all columns, if no row,: no key
    2) scan columns till row active = key found
    3) at exit if now_key is not = prev_key ignore
    4) if 2 identical reads and result different from last key presented present key.
