EC++ and predefined version number macros
I would like to test the version of both the EC++ and C compilers and return an #error message if they don't match what it is supposed to be. Just to make sure that no-one will compile and run the code with another toolchain without being warned.
So here it goes, in a .cpp file:
// test.cpp
#ifdef __cplusplus
#if __EC166__ != 109
#error Wrong EC++ compiler version
#endif
#endif
#if __C166__ != 0
#error Wrong C compiler version
#endif
unsigned int i;
// end of file
It compiles successfully (!) and yields the test.ic file:
// v_2.45.2, Fri Oct 28 19:01:33 2005
#line 1 "deleteme.cpp"
#line 12
unsigned i = 0;
So my question is:
How comes that __C166__ evaluates successfully to 0 when a file is compiled with EC++? To me, it is not supposed to be a predefined EC++ macro constant, and should just be expanded in the .ic file?
Of course this doesn't compile with EC++, even though that's what I would like to have:
// test.cpp
#ifdef __cplusplus
#endif
#endif
#if __C166__ != 602
#error Wrong C compiler version << error here
#endif
unsigned int i;
// end of file
Even though EC++ calls the C compiler, which happens to be version 6.02...
Now this .c file:
// test.c
#ifdef __cplusplus
#endif
#endif
#if __C166__ != 602
#endif
unsigned int i;
// end of file
Compiles successfully with the C compiler.
I would really like to test both the EC++ AND the C version. Is there any workaround?
Thank you very much for your help and for reading me,
-Stéphane
_______________________________
I am using the following toolchain:
IDE-Version:
µVision3 V3.21
EC++ Compiler: EC166.Exe V1.09
C Compiler: C166.Exe V6.02
Assembler: A166.Exe V5.20
Linker/Locator: L166.Exe V5.21
Librarian: LIB166.Exe V4.26
Hex Converter: OH166.Exe V4.7a
CPU DLL: S166.DLL V2.49
Dialog DLL: D167.DLL V2.45
