Hi all How to write a pragram to subtraction immediate data from accumulator with borrow in C51?
Er.. SUBB?
. . MOV A,EX SUBB A,X INC A MOV xbuffer,A . . The C51's code is " xbuffer=(EX-X)+1; " that correct? C51 not same instruction so anyone can for explain with a simple program has SUBB same function.
Sorry, I'm lost. Are you trying to write 'C' or assembler?
I am trying a C code, the "xbuffer=(EX-X)+1;" is correct if original code as following: . . MOV A,EX SUBB A,X INC A MOV xbuffer,A . .
"I am trying a C code, the "xbuffer=(EX-X)+1;" is correct if original code as following: . . MOV A,EX SUBB A,X INC A MOV xbuffer,A" The assembler code behaves differently depending on the value of the carry flag, so I guess the answer is no. Are you trying to translate an assembler program into 'C'?
Yes, if it isn't correct. How to write a C code?
"Yes, if it isn't correct. How to write a C code?" You can't, or at least not meaningfully. While it is safe enough to read the carry flag in 'C' its value doesn't mean anything useful. Look at the bigger picture - figure out what the assembler program does and reproduce that in 'C'. Don't try to translate it one instruction at a time. Translate the algorithm instead.
How to write a pragram to subtraction immediate data from accumulator with borrow in C51? In C51 you don't. If you want to fiddle with the accumulator and the carry flag, C is not, repeat: not the language to do it in. If you want to program assembler, do it in assembler.
Translate the algorithm instead. So anyone can for explain a simple program.
"So anyone can for explain a simple program." The subject of your question is a perfect example. The 8051 is an 8-bit processor, so all its instructions deal with only 8 bits at a time. Therefore, if you want to handle data larger than 8 bits in Assembler, you have to "manually" code it 8 bits at a time. The Subtract-with-Borrow (and, similarly, Add-with-Carry) instruction allows you to do subtraction on data larger than 8 bits by handling 8 bits at a time, and including a "borrow" from the previous 8-bit operation. In 'C', you don't mess about with all this detail - you just use the 16-bit data type (int) or 32-bit data type (long) built into the language!
long a, b, c; a = b - c; // 32-bit subtraction in 'C' is just a simple use of the '-' operator!
