Hi: I tried the following code:
#include <LPC21XX.h> #include <stdio.h> #define OSC_CLOCK_FREQ 14745600 #define CR 0x0D void UARTInitialize(unsigned int baud) { U0LCR = 0x83; /* 8 bit, 1 stop bit, no parity, enable DLAB */ U0DLL = 192; /* 9600 bps @ Peripheral Clock = 2 * 14745600 MHz */ U0DLM = 0; U0LCR &= ~0x80; /* Disable DLAB */ PINSEL0 = (PINSEL0 & ~0xF) | 0x5; U0FCR = 1; } unsigned int cClkFreq(void) { return (OSC_CLOCK_FREQ * (PLLCON & 1 ? (PLLCFG & 0x1F) + 1 : 1)); } unsigned int pClkFreq(void) { unsigned int divider=0; switch (VPBDIV & 3) { case 0: divider = 4; break; case 1: divider = 1; break; case 2: divider = 2; break; } return cClkFreq() / divider; } int putchar(int ch) { if (ch == '\n') { while (!(U0LSR & 0x20)); U0THR = CR; } while (!(U0LSR & 0x20)); return (U0THR = ch); } int main (void) { UARTInitialize(9600); printf("Processsor Clock %d\n", cClkFreq()); printf("Peripheral Clock %d\n", pClkFreq()); printf("Peripheral Clock %d\n", pClkFreq()); printf("Peripheral Clock %d\n", pClkFreq()); while (1) ; return 0; }
Probably your problem relates to the following LPC2129 errata sheet topic:
VPBDIV.1 Incorrect read of VPBDIV Introduction: The Peripheral Bus Divider (VPBDIV) divides the processor clock (CCLK) by one, two, or four. This is the clock that is provided to the peripheral bus. Problem: Reading the VPBDIV register may return an incorrect value. Work-around: Performing two consecutive reads of the VPBDIV assures that the correct value is returned.
