Simulating an external memory location
I'm converting from Metalink's metaice for my 87c51 development. I'm having trouble figuring out how to dynamically adjust the external memory locations that I'm using for external port inputs. The port numbers are 8003h, 8004h, and 8005h respectively for the A/D converters and in metaice I could easily click on the "external code data" window and dynamically plug in the hex value I needed and adjust it to simulate the program against the hardware with that value when the DPTR calls for that location data. It seems that Keil requires that I manually type the values directly into the registers when it is called which is fine on a single event, but I have like 300 variables to deal with over the 32 banks of data and need an easier way to not have to manually fake the data.
Any ideas of a shortcut to help me out with this? Is there a simple memory window that lists the external memory data that I can adjust dynamically so when I single step the program those values get pulled in as if the A/D's are actually dumping data from those ports? I'm sure its something simple, I can't seem to figure it out.
Chris
  • I found it, I have to open the memory window and type in the address in this case x:0x???? and right click and hit the modify byte. Works like a champ
    Now, one thing I don't understand, it is taking the number I plug in and translate it to hex. Is there any way to set the options so that it is a direct hex plug in instead of having to use a decimal to hex conversion?
  • Now, one thing I don't understand, it is taking the number I plug in and translate it to hex. Is there any way to set the options so that it is a direct hex plug in instead of having to use a decimal to hex conversion?
    Input format follows the C language.
    Numbers prefixed with 0x are HEX
    Numbers prefixed with 0 are octal
    Numbers with no prefix are decimal
    Jon
  • Jon
    Thank you for the clarification, I should have realized that from the git go. Now that I think of it, the modification of the registers in metalice required the 0x?? format. But it is pretty cool that Keil translates my decimal equivalent the proper hex value that sequences my program.....an unexpected pleasure.
    Thanks again for the help
    Chris
