In my project, Some events must be checked per 1ms.so i want to add the code to the tick ISR in the conf_tny.a51. but i do not want the Task Switching tick so small. i want to Keep the Task Switching time be 10ms. maybe the struct is as below: //enter 1ms ISR //update the THO TL0. //check the events //update the times counter //end 1ms ISR //if(counter >= 10) // { // begin the Task Switching. // } woudl you teach me to how to adjust the conf_tny.a51 file and how to add my events checking code into 1ms ISR? maybe you could give me an example about it. thanks.
up.
