I am interfacing with a Graphic LCD (resolution 64*128) and i have to display all the ASCII characters till 7F (hex), for this i am having a 1K .dat file containing the information regarding the 7X5 format of all ASCII characters. Now i need to use this .dat file in my C code, to get the equivalent 7X5 format of the ascii input. How can i do this , Any suggestions ?
Write a PC application (VB, MSVC, Delphi, Perl, whatever) to read the .dat file and write a corresponding 'C' source representation; eg, an initialised array?
or simply do a few keystrokes using a REAL editor such as CodeWright. Erik
http://www.keil.com/support/docs/2218.htm
You could also try http://srecord.sourceforge.net/
