Hi, I am trying to get support for a programming algorithm for a Toshiba Flash device, we need a TC58FVM5B2A.FLX file which Keil have agreed to supply. Could you please supply this file as soon as possible........we need this very urgently ! I have tried to contact Hans Schneebauer but have had NO reply. Part Number TC58FVM5B2AFT65 Product Category NOR Flash Capacity 32 Mbits Data width 16 Bit Peter. Ramzi Kattan wrote: > Hi Peter, > > Keil have supplied the source code for the 64Mbit part, which you can modify to support your flash part. For historical reasons you will need the ARM ADS compiler to compile the code, so Keil have offered to do the compilation for you. > > I will be out of the office next week, so i suggest you liase directly with Hans Schneebauer of Keil if you have any issues with the port. > > Regards, > Ramzi > > > Solutions for your embedded development > > Ramzi Kattan > Managing Director Embedded Logic Solutions Pty Ltd > 391 Hume Highway > Bankstown NSW 2200 > Australia > ramzi.kattan@emlogic.com.au > tel: > fax: > mobile: +61 2 9793 9542 > +61 2 9790 1183 > +61 413 01 4233 >
We have send you this algorithm already. So, please give us in the future a little more time to re-act. Reinhard
