Hello, I want to get started with Keilsoftware and so I write some little programs to get more knowledge of these program. I wrote a small example simulation between Keil and Phytec SK-167-CR. After starting debug session the monitor is loading and I got the message "connecting target failed". I think it is a problem with the bootstraploader. Maybe some of you could help me. Jim
Phytec has many different board variants. But the example in the folder C:\Keil\C166\Boards\Phytec KC167CR may work. If it still fails you may need to configure a Monitor. Refer to the file C:\Keil\C166\Monitor\Readme.txt for more information. Reinhard
