C11 internal error
Compiling something like this:
typedef char near * SWITCHES_LIST[];
typedef SWITCHES_LIST near * SWITCHES_LIST_POINTER;
typedef struct
void near *switches;
} PISTON;
int sub (PISTON *p)
int index;
if (*((*((SWITCHES_LIST_POINTER) p->switches))[index]))
I get: "error C11: internal error: (asmgen - triple=t0322)" on "if" row.
These rows has been extracted from a large project. Lowering the "code optmimization level" to 0 does not change anything. But I am not able to reproduce the error in a sample project.
All the project has been "linted" succesfully, so I am quite sure that there are not syntax errors.
I have been able to compile only breaking down the "if" in 2 rows, like:
switches = (SWITCHES_LIST *) piston->forward_switches;
if (*((*switches)[index]))
Did somebody have already seen something like this ???
  • "I get: "error C11: internal error: (asmgen - triple=t0322)" on "if" row."
    Congratulations! You've broken the compiler. Clearly it doesn't like typedef any more than I do.
    Seriously though, you need to report this to Keil. Either you've exceeded the expected limits of the compiler (unlikely) or you've found a bug, albeit one that is handled gracefully.
  • I have been able to compile only breaking down the "if" in 2 rows, like:
    With such a horrendously complicated expression as that, it is certainly a good idea to break it down - probably even further than you have already!
    Can you honestly say that you can just look at a line like
    and say for sure that you know precisely what it does?
