RTX51Tiny process restart
Is there a recommended method for restarting an RTX51Tiny process in case of hoseup - something less drastic than restarting the entire processor (e.g. via a watchdog)? I have several interlocking processes that may lose synchronization, and want to be able to restart them as a last resort, say from a monitor process or long-duration timer interrupt.
  • You're asking for the impossible. It's basically the definition of a "hose-up" that nothing less drastic than a hardware watchdog bite will get you out of it, because everything else has been tied in the hose-up.
    You're effectively asking the wrong question. It's unimportant how you get out of a hose-up --- the trick is never to get into one.
  • Well, when you have multiple processors trying to communicate, sometimes things can go askew. For instance, I have an embedded system trying to talk to a host system over an RF link. It is possible that the host can drop off in the middle of a tranmission, in which case I have to reset the protocols and go back to waiting for contact initiation. I could put tests into every point where I wait for a reply (basically where the interchange handler sends something and then calls os_switch_task while it's waiting for a reply) or I could just set a long duration (say 10 second) timer and have the timer ISR reset the protocol handler.
  • "Well, when you have multiple processors trying to communicate, sometimes things can go askew."
    This is precisely why protocol stacks are expensive!
    It has been said that only, say, 10% of the development work goes into handling the case where everything goes right - the other 95% goes into handling all the possible failure conditions!
    "I could put tests into every point where I wait for a reply"
    There is no "could" about it - you must have those tests!
    "or I could just set a long duration (say 10 second) timer and have the timer ISR reset the protocol handler"
    Well, if you're happy that your comms keeps locking up for 10s at a time...
  • It is possible that the host can drop off in the middle of a tranmission, in which case I have to reset the protocols and go back to waiting for contact initiation.
    Well, that's not a hose-up. That's just a plain vanilla protocol time-out. How exactly that has to be handled depends on the details of the protocol, and potentially on the reasons for the time-out.
    Other than that, the only possible comment is that well, all the trivial things have long since been done by others, so guess what's left for you ;-)
