i need help
hello! i want to know about the code which ca be use to decode a encoded sequence in the form of 0 and 1
  • everything in digital electronics is encoded as sequences of 0 and 1!
    You question is so vague as to be entirely unanswerable!
    Please supply a fuller description of your problem.
    Don't forget to specify which Product you are using (choose from the drop-down list)
