Is it possible, to export the content of the memory?? e.g. the external memory from address X:0x0000 until address 0x00FF into a file? I have in mind, to make an excel-sheet with the data in the memory.
http://www.keil.com/support/man/docs/uv3/uv3_cm_save.htm
Thank you very much!!
Good question ! Good answer ! Learned some new. I had really overread it too. - Stefan -
