Hi all, This is my first program that I downloaded to the flash memory after modifying the Keil MCB251 board for flash programming. I used the ATMEL flip to download the Blinky program to the MCB251 board which has T89C51RD2. The programming and verifcation are done correctly .After downloading I couldnot see the blinky program running there.I would like to know how I could run program after downloading it to the flash memory? Looking for your help.
The T89C51RD2 is not an 80251; it's just a plain 8051 derivative. If you're really using C251, you should switch to C51 No doubt C251 could be configured to generate code for a plain 8051, but why bother? Use the correct tool for the job. It looks like you need to start with the basics - not introduce extra, unnecessary complications!
If you're really using C251, you should switch to C51 I am using C51 and not C251. the keil board says MCB251 thats why i wrote it like it.......
