Hi I am not very familiar with "makefiles". I read that is a way to tell the compiler the order and organization of the files; I guess it is like creating a project in uvision, but i am not sure. Anyway, i have a set of files that were created with a makefile, and i don't know hot to create the project from it, can anybody help me? Thanks
i have a set of files that were created with a makefile, and i don't know hot to create the project from it, can anybody help me? Post the makefile. I use them Erik
here is the make file, it is kind of big:
WIN32OBJ= __out__\w32C51OBJ = __out__\c51 KEILROOT=D:\DEVELOP\KEIL CC = wpp386 CXX = wpp386 CFLAGS = -zq -w1 -bm -bt=NT -d2 -d__WEMU__ -dNO_KEYSOFT -d_CPU_X86 -fh=$(WIN32OBJ)stdafx.pch CXXFLAGS= $(CFLAGS) LINK = wlink LFLAGS = op quiet op c sys nt debug all .EXTENSIONS: .EXTENSIONS: .exe .hex .obj .cpp .c OBJECTS=wemu.obj ipcmapping.obj snifftxrx.obj KBUWB00.obj KBU00004.obj KBU00011.obj sku20003.obj sku20004.obj cmkey_s.obj #cmkey_e.obj TARGET = wemu.exe TARGET2 = KBU00004.hex KBU00011.hex sku20003.hex sku20004.hex cmkeyS00.hex cmkeyE00.hex kbuwb00.hex display_hex TMPLIST = wemu.xxx ####### Build rules #all: MAKEDIR $(TARGET2) .SYMBOLIC all: MAKEDIR $(TARGET2) .SYMBOLIC @pause MAKEDIR: .SYMBOLIC @if not exist $(WIN32OBJ) @mkdir $(WIN32OBJ) @if not exist $(C51OBJ) @mkdir $(C51OBJ) @if exist wemu.exe @del wemu.exe $(TARGET): $(OBJECTS) @if exist *.*~ del *.*~ @%create $(TMPLIST) @%append $(TMPLIST) NAME wemu @for %w in ($(OBJECTS)) do @%append $(TMPLIST) FILE $(WIN32OBJ)%w @$(LINK) $(LFLAGS) @$(TMPLIST) @del $(TMPLIST) @echo ======BUILD: $(TARGET) done.======= display_hex: .SYMBOLIC -agrep IDATA $(C51OBJ)*.m51 -agrep "CODE SIZE" $(C51OBJ)*.lst ####### Compile .obj: $(WIN32OBJ) .cpp: ..c : ..c.obj: .AUTODEPEND @echo --------win32 compiling $^&----------------------- @$(CXX) $(CXXFLAGS) $(INCPATH) -fo=$(WIN32OBJ)$^&.obj $^&.c .cpp.obj: .AUTODEPEND @echo --------win32 compiling $^&----------------------- @$(CXX) $(CXXFLAGS) $(INCPATH) -fo=$(WIN32OBJ)$^&.obj $^&.cpp cmkeyS00.obj: msc\cmkey_s.cpp .AUTODEPEND @echo --------win32 compiling $^&----------------------- @$(CXX) $(CXXFLAGS)/DCMKEY_S $(INCPATH) -fo=$(WIN32OBJ)$^&.obj msc\cmkey_s.cpp #cmkeyE00.obj: cmkey000.c .AUTODEPEND # @echo --------win32 compiling $^&----------------------- # $(CXX) $(CXXFLAGS) /DCMKEY_E $(INCPATH) -fo=$(WIN32OBJ)$^&.obj $[&.c C51DEFINES=DEFINE(_CPU_8051) OPTIMIZE(SIZE) #OUTPUTLOG=output.lg OUTPUTLOG=con .hex: $(C51OBJ) KBU00004.hex: KBU00004.c @echo --------compiling $^&----------------------- @SET PATH=$(KEILROOT)\C51\BIN;$(%PATH) @SET TMP=C:\TEMP @SET C51INC=$(KEILROOT)\C51\INC\Atmel @SET C51LIB=$(KEILROOT)\C51\LIB @C51.EXE $^&.c $(C51DEFINES) PRINT($(C51OBJ)$^&.lst) OBJECT($(C51OBJ)$^&.obj) #SMALL ROM(SMALL) @-bl51.EXE $(C51OBJ)$^&.obj TO $(C51OBJ)$^&.bl REGFILE ($(C51OBJ)$^&.ORC) PRINT ($(C51OBJ)$^&.m51) CODE (0X0000-0X0FFF) @OH51.EXE $(C51OBJ)$^&.bl HEX($(C51OBJ)$^&.hex) @echo C51: HEX $^& done. @del $(C51OBJ)$^&.bl @del $(C51OBJ)$^&.obj @del $(C51OBJ)$^&.orc # @-lpp $(C51OBJ)$^&.lst indent(30) @hexc 4051 $(C51OBJ)$^&.hex Y:\atprog\$^&.hex sku20003.hex: sku20003.c @echo --------compiling $^&----------------------- @SET PATH=$(KEILROOT)\C51\BIN;$(%PATH) @SET TMP=C:\TEMP @SET C51INC=$(KEILROOT)\C51\INC\Atmel @SET C51LIB=$(KEILROOT)\C51\LIB @C51.EXE $^&.c $(C51DEFINES) PRINT($(C51OBJ)$^&.lst) OBJECT($(C51OBJ)$^&.obj) #SMALL ROM(SMALL) @-bl51.EXE $(C51OBJ)$^&.obj TO $(C51OBJ)$^&.bl REGFILE ($(C51OBJ)$^&.ORC) PRINT ($(C51OBJ)$^&.m51) CODE (0X0000-0X0FFF) @OH51.EXE $(C51OBJ)$^&.bl HEX($(C51OBJ)$^&.hex) @echo C51: HEX $^& done. @del $(C51OBJ)$^&.bl @del $(C51OBJ)$^&.obj @del $(C51OBJ)$^&.orc # @-lpp $(C51OBJ)$^&.lst indent(30) @hexc 4051 $(C51OBJ)$^&.hex Y:\atprog\$^&.hex KBU00011.hex: KBU00011.c @echo --------compiling $^&----------------------- @SET PATH=$(KEILROOT)\C51\BIN;$(%PATH) @SET TMP=C:\TEMP @SET C51INC=$(KEILROOT)\C51\INC\Atmel @SET C51LIB=$(KEILROOT)\C51\LIB @C51.EXE $^&.c $(C51DEFINES) PRINT($(C51OBJ)$^&.lst) & OBJECT($(C51OBJ)$^&.obj) #SMALL ROM(SMALL) @-bl51.EXE $(C51OBJ)$^&.obj TO $(C51OBJ)$^&.bl REGFILE ($(C51OBJ)$^&.ORC) PRINT ($(C51OBJ)$^&.m51) CODE (0X0000-0X0FFF) @OH51.EXE $(C51OBJ)$^&.bl HEX($(C51OBJ)$^&.hex) @echo C51: HEX $^& done. @del $(C51OBJ)$^&.bl @del $(C51OBJ)$^&.obj @del $(C51OBJ)$^&.orc # @-lpp $(C51OBJ)$^&.lst indent(30) @hexc 4051 $(C51OBJ)$^&.hex Y:\atprog\$^&.hex sku20004.hex: sku20004.c @echo --------compiling $^&----------------------- @SET PATH=$(KEILROOT)\C51\BIN;$(%PATH) @SET TMP=C:\TEMP @SET C51INC=$(KEILROOT)\C51\INC\Atmel @SET C51LIB=$(KEILROOT)\C51\LIB @C51.EXE $^&.c $(C51DEFINES) PRINT($(C51OBJ)$^&.lst) OBJECT($(C51OBJ)$^&.obj) #SMALL ROM(SMALL) @-bl51.EXE $(C51OBJ)$^&.obj TO $(C51OBJ)$^&.bl REGFILE ($(C51OBJ)$^&.ORC) PRINT ($(C51OBJ)$^&.m51) CODE (0X0000-0X0FFF) @OH51.EXE $(C51OBJ)$^&.bl HEX($(C51OBJ)$^&.hex) @echo C51: HEX $^& done. @del $(C51OBJ)$^&.bl @del $(C51OBJ)$^&.obj @del $(C51OBJ)$^&.orc # @-lpp $(C51OBJ)$^&.lst indent(30) @hexc 4051 $(C51OBJ)$^&.hex Y:\atprog\$^&.hex cmkeyS00.hex: cmkey000.c @echo --------compiling $^&----------------------- @SET PATH=$(KEILROOT)\C51\BIN;$(%PATH) @SET TMP=C:\TEMP @SET C51INC=$(KEILROOT)\C51\INC\Atmel @SET C51LIB=$(KEILROOT)\C51\LIB C51.EXE $[&.c $(C51DEFINES) DEFINE(CMKEY_S) PRINT($(C51OBJ)$^&.lst) OBJECT($(C51OBJ)$^&.obj) #SMALL ROM(SMALL) @-bl51.EXE $(C51OBJ)$^&.obj TO $(C51OBJ)$^&.bl REGFILE ($(C51OBJ)$^&.ORC) PRINT ($(C51OBJ)$^&.m51) CODE (0X0000-0X0FFF) @OH51.EXE $(C51OBJ)$^&.bl HEX($(C51OBJ)$^&.hex) @echo C51: HEX $^& done. @del $(C51OBJ)$^&.bl @del $(C51OBJ)$^&.obj @del $(C51OBJ)$^&.orc # @-lpp $(C51OBJ)$^&.lst indent(30) @hexc 4051 $(C51OBJ)$^&.hex Y:\atprog\$^&.hex cmkeyE00.hex: cmkey000.c @echo --------compiling $^&----------------------- @SET PATH=$(KEILROOT)\C51\BIN;$(%PATH) @SET TMP=C:\TEMP @SET C51INC=$(KEILROOT)\C51\INC\Atmel @SET C51LIB=$(KEILROOT)\C51\LIB C51.EXE $[&.c $(C51DEFINES) DEFINE(CMKEY_E) PRINT($(C51OBJ)$^&.lst) OBJECT($(C51OBJ)$^&.obj) #SMALL ROM(SMALL) @-bl51.EXE $(C51OBJ)$^&.obj TO $(C51OBJ)$^&.bl REGFILE ($(C51OBJ)$^&.ORC) PRINT ($(C51OBJ)$^&.m51) CODE (0X0000-0X0FFF) @OH51.EXE $(C51OBJ)$^&.bl HEX($(C51OBJ)$^&.hex) @echo C51: HEX $^& done. @del $(C51OBJ)$^&.bl @del $(C51OBJ)$^&.obj @del $(C51OBJ)$^&.orc # @-lpp $(C51OBJ)$^&.lst indent(30) @hexc 4051 $(C51OBJ)$^&.hex Y:\atprog\$^&.hex kbuWB00.hex: kbuWB00.c @echo --------compiling $^&----------------------- @SET PATH=$(KEILROOT)\C51\BIN;$(%PATH) @SET TMP=C:\TEMP @SET C51INC=$(KEILROOT)\C51\INC\Atmel @SET C51LIB=$(KEILROOT)\C51\LIB C51.EXE $[&.c $(C51DEFINES) PRINT($(C51OBJ)$^&.lst) OBJECT($(C51OBJ)$^&.obj) #SMALL ROM(SMALL) @-bl51.EXE $(C51OBJ)$^&.obj TO $(C51OBJ)$^&.bl REGFILE ($(C51OBJ)$^&.ORC) PRINT ($(C51OBJ)$^&.m51) CODE (0X0000-0XFFFF) @OH51.EXE $(C51OBJ)$^&.bl HEX($(C51OBJ)$^&.hex) @echo C51: HEX $^& done. @del $(C51OBJ)$^&.bl @del $(C51OBJ)$^&.obj @del $(C51OBJ)$^&.orc
as far as I can see It will run if you have the tools at a KEILROOT directory. It is, as made quite a blabbermouth, I prefer commandfiles that only "speak" when trouble or completely done. Erik
The full workings of that makefile won't be easily reproducible in uVision (at least not in uVision2), because that won't make multiple targets in a single run. To build those .hex files in uVision would be quite trivial: it won't take more than creating a project, adding one .c file to it, maybe selecting a few options, and that's it. Then hit "build" and compare the .lst files to those you got from the makefile build. Lather, rinse, repeat until they're identical.
because that won't make multiple targets in a single run. I do that routinely with .bat files an example:
if "%1"=="s" goto gams call makp ar %2 call makp br %2 call makp as %2 call makp bs %2 if "%1"=="p" goto end :gams call maks a %2 call maks aa %2 call maks b %2 call maks ba %2 call maks l %2 rem call maks t %2 :end
"that [uVision] won't make multiple targets in a single run" Yes, that can be a pain. uVision could really do with a "Build ALL Targets" option.
I created a project and included one of the files (which I think it is the main file) and the compilation did not show any errors, hopefully that will work. I will simulate it later and see if that works, but anyway i still don't know how the makefile works. William
Yes, that can be a pain. uVision could really do with a "Build ALL Targets" option. I have several "build multiple" cases and I really doubt there is any way to make an IDE such as uVision do it. 1) I mostly build just one - after all you can only debug one build at a time and use a file like the above to build them all for buildability test or release. 2) the "external variables" to create the individual build of the multiples can have many different formats. Some cases it is file select and some cases it is #ifdef control and sometimes it file select and rename and sometimes .... . So, I would say "forget IDE multibuild, but make the uVision components run smoothly from the commandline (basically they do)" and leave the multibuild to our build files. Just please, pretty please stop bugging us with "why do you not use the IDE". Should anyone have any illusions about multibuild being "simple" I'll gladly post the .bats Erik
I have several "build multiple" cases and I really doubt there is any way to make an IDE such as uVision do it. Sure there is. All it takes is to allow targets to be added as "things to be built" to other targets. Then all you have to do is to have a main target that includes all others, and building that will build them all, one after the other. uVision already gets the rest of the job right (easier than with makefiles, actually): it recognizes that if you change targets, all previous .obj files have to be recompiled, so "change target, build target" is automatically equivalent to "change target, rebuild target from scratch".
Hans-Bernhard, You just totally bypass the "target switching" an example from a .bat
IF "%1"=="a" goto lca IF "%1"=="aa" goto lcaa IF "%1"=="b" goto lcb IF "%1"=="ba" goto lcba IF "%1"=="l" goto lcl IF "%1"=="t" goto lct :lca copy ..\sc\cond\sfa.h condit.h >..\trash\trashbin copy ..\ss\usmaina.c usmain.x >..\trash\trashbin copy ..\ss\usledst1.c usledstb.x >..\trash\trashbin copy ..\ss\ussgndv1.c ussgndvr.x >..\trash\trashbin goto lxx
