Using Infineon XC866-4FR I am trying to read two A/D channel results and printing the outputs to SBUF. The results are 255 < result6 < 32607 and result7 always 0. Here is the code: #include "MAIN.H" #include <stdio.h> ubyte result6, result7; void message( char *pucMessage ); void MAIN_vInit(void) { /// Initialization of module 'GPIO' IO_vInit(); /// Initialization of module 'UART (Serial Interface)' UART_vInit(); /// Initialization of module 'Analog / Digital Converter (ADC)' ADC_vInit(); // Interrupt Priority IP = 0x00; // load Interrupt Priority Register IPH = 0x00; // load Interrupt Priority High Register IP1 = 0x00; // load Interrupt Priority 1 Register IPH1 = 0x00; // load Interrupt Priority 1 High Register // USER CODE BEGIN (MAIN_Init,3) // USER CODE END // globally enable interrupts EA = 1; } // End of function MAIN_vInit void main(void) { char msg[50]; MAIN_vInit(); while(1) { ADC_PAGE = 0x06; ADC_CRPR1 |= 0x40; // generate load event while(ADC_ubBusy()); // wait until conversion complete ADC_PAGE = 0x02; if(ADC_RESR2L & 0x10) // check whether the result is valid { result6 = ADC_RESR2H; // read 8-bit result } PORT_PAGE = 0x00; ADC_PAGE = 0x06; ADC_CRPR1 |= 0x40; // generate load event while(ADC_ubBusy()); // wait until conversion complete ADC_PAGE = 0x02; if(ADC_RESR3L & 0x10) // check whether the result is valid { result7 = ADC_RESR3H; // read 8-bit result } PORT_PAGE = 0x00; sprintf(msg,"\n\n\xd %d - This is the result from Channel 6" , result6); message(msg); sprintf(msg,"\n\n\xd %d - This is the result from Channel 7" , result7); message(msg); } } // End of function main void message( char *pucMessage ) { // while the character is not 0 while (*pucMessage) { SBUF = *pucMessage++; while (TI == 0) {;} TI = 0; } return; }
Your printf() format specifiers are wrong.
Do you mean the %d ?
Yes, you need %bu.
