We can't load an aplication into a ds5000t using mon51!!!!
Hi friends! We loaded the ds5000_mon_9600_110592.hex from keil web because we're using an DS5000t. We loaded this hex file with kit. After this we have made an proyect with keil very simple. The problem is that we can't get this code to load into the micro. We established the correct baud rate (9600) but each time we try to load it we get a keil window where it tells us that the comunication seem to be lost. I don't know what else to do. Plese a I'll be very pleased if you can help us. Thanks.
