I'm trying to use the RTC_event of the PCD6001. I've put a "sbit RTC_interrupt_Enable 0xEF" and when i try to set the RTC_interrupt_Enable to '1', the compilator say me that the variable is undefined, but as u see, i've defined it with the sbit command. But it's work very well with the Global Interrupt Enable, i set a "sbit" to adress it, and i can set it to one without any errors. Whats the problems please ? Thanks!
"sbit RTC_interrupt_Enable 0xEF" You've missed out an operator.
Hoo pardon, i miss the '=', In my code there is in fact : 'sbit RTC_Interrupt_Enable = 0xEF' And i dont see where is the problem
Can you post your real code and the actual error meesage from the listing file? Describing programming in prose is like reading a description of the sistine chapel. Jon
I've put a "sbit RTC_interrupt_Enable 0xEF" whr hv u pt it ? But it's work very well with the Global Interrupt Enable u nt 2 st sm pl ? I try tyo keep your style. Since you do not want to be bothered with typing unnecessary characters i leave it to you to decode and answer the questions above Erik
