help!why my fifowrite wave can't run correctly?
hello
i am having a problem to the gpif with cy7c68013.that is i can't start then fifowrit
wave correctly.i use endpoit2 for out bulk,but when trigger then fifowrite,it only at idle but then 'DONE'b bit is asserted.and can't out then gpif.
so what should i do,thanks.
