Using different set of source files for different targets
Hi:
I would like to have one project with two targets, where each target requires a different set of source files. For example, a target with an ethernet interface would require the ethernet drivers, while others do not require it.
I tried to make it with the Manage Components option, but when I add a file to a group in one targe, the file also appears in the other target.
Is there a way to do this?
Thanks in Advance!
Gus
  • Use the 'Include in Target build' option - either on individual files, or on file Groups.
    You cannot have files present in one Target but not another, but you can set the 'Include in Target build' option on a per-Target basis.
