Which Keil function for P0 and P2 as I/O
Hi all,
I am using P0 and P2 for I/O but I dont know which Keil function for reading and writing to a specific address.
I think this problem can be solve by( :) ?)
MOV DPH, 0xFF
MOV DPL, 0xFF
MOVX A, @DPTR
Pls help me for this problem by C language for Keil
Thanks and best regards
bocphet
  • Accessing the 8051's IO ports is described in the uVision Getting Started Guide under the heading "Parallel Port I/O"
    Cryptic, I know, but there it is...
    Please read the uVision Getting Started Guide, and work through the example projects in it.
    This will give you a proper introduction to the tools, how they work, and how to use them - rather than just jumping-in blindly at the deep end.
    (The uVision Getting Started Guide is available on the 'Books' tab in the 'Project' Window; The 'Books' window is also available via the 'Help' menu; failing all that, search for GS51.PDF in your Keil folder)
  • Thank you, but the manual and example only about one port
    But my problem is using 2 ports for address and data bus at the same time for access specific address of RAM, for example. So which function I should use or How can I do with that
    Brgds,
  • XDATA accesses are generated for variables defined as 'xdata'
    For memory-mapped IO, take a look at the _at_ keyword extension.
