Hi I just bought the MCB900 ver.4 with LPC935. I have programmed the first demo program into the flash - CheckLed - and it works fine on the eval board. I have many experiences with the old non Keil DOS assembler but I don't know yet to manage Keil A51. As I have found there are only C examples on the CD, but this is useless for me. PLEASE, can somebody save me some hours and show the short *.A51 program which will flash or do something else with the MCB900 on board LEDs. I really can't understand why I can't find some A51 examples on the enclosed CD.
Excuse me, please, I have just find the subject 7012, where this question was done. So please you don't need to reply on my question again. Sorry.
"I have just find the subject 7012" Eh? Do you mean this: http://www.keil.com/forum/docs/thread7012.asp
Thank you, Neil, for your reply. Of course I have that files in the mentioned directory. But I need a real working assembler project not only *.A51 file. I still don't know to write a ''project'' with a few lines assembler code, which will - for example - force F0h to the P2 (this will ligh on four P2 LEDs). Can somebody post that few lines, please ? Thank you.
"But I need a real working assembler project not only *.A51 file." My CD has a complete set of project files:
D:\KEIL\c51\Examples\A51>dir Volume in drive D is LPC_2_2003 Volume Serial Number is EA7C-B5D9 Directory of D:\KEIL\c51\Examples\A51 01/01/1601 12:34 <DIR> . 01/01/1601 12:34 <DIR> .. 13/09/1996 06:10 84 ABSTRACT.TXT 08/09/1999 10:49 251 ASAMPLE.BAT 17/09/1999 14:35 1,004 ASAMPLE.OPT 17/09/1999 14:35 1,865 ASAMPLE.UV2 17/06/1989 12:30 1,083 ASAMPLE1.A51 08/09/1999 10:46 804 ASAMPLE2.A51 17/06/1989 12:30 344 ASAMPLE3.A51 13/09/1996 06:10 9,341 TEMPLATE.A51 8 File(s) 14,776 bytes 2 Dir(s) 0 bytes free
A.W. Neil, many thanks for your help. I only added the following 3 lines to the ASAMPLE1 and on board LEDs light in according with the third line. From now it will go more easy. sfr P2M1 = 0xA4; MOV P2M1,#0 MOV P2,#01010101B
Hi Folks, Could someone explain the difference between using putchar and mov to send data to a serial port? They seem functionally the same to me. thanks, John
"They seem functionally the same to me." Not at all. MOV is a single processor instruction. putchar is a function; ie, a sequence of instructions that you call to perform some required operation. The putchar function in the ASAMPLE expample first waits for the TI flag to be set, then clears it, then uses a MOV instruction to copy the byte from the Accumulator into SBUF, then returns. The putchar function provided in the C51 library also expands '\n' into CR LF and handles XON/XOFF software flow control.
