huge to far
I think I finally found a Problem which caused me Trouble over the past Days, and now I'm trying to find a satisfying solution.
I'm using an Infineon XC161CJ with a grapical Display.
I use a struct which defines a variable width font:
typedef struct
// Font Bitmap Array
const ubyte huge *ubElement;
// Element Width
const ubyte *ubElementWidth;
} LCD_sFont;
const LCD_sFont cgsFont24x23 = {...};
The font array exceeds 16K so it must be declared as huge.
The Function which prints out the single characters expects a far pointer.
Obviously it causes trouble when accessing the character of the huge-array crossing the 16k page boundary by simply passing the adress of the huge-array + offset.
I would be glad to know if there is a posibility to get out of this without changing the Parameter of the Display-Function or making a temporary copy of the actual character.
A simple cast would be perfect but I'm afraid the solution will not be that easy ...
Thx and Best Regards,
Marcus
