/*------------------------------------------------ Function for memory write ------------------------------------------------*/ void EeWrite() { temp_prog = PROG_NO - 0X30; WMCON |= EEMEN_; WMCON |= EEMWE_; program[temp_prog].e_total_turns = prog.total_turns; program[temp_prog].e_stop1_turns = prog.stop1_turns; // same copying code here... for( i=0; i < 2500; i++ ) { if( WMCON & EERDY_ ) break; } WMCON &= ~EEMEN_; // EEMEN=1; WMCON &= ~EEMWE_; // EEMWE_=1; }
/*------------------------------------------------ Function for memory read ------------------------------------------------*/ void EeRead() { temp_prog = PROG_NO - 0X30 WMCON |= EEMEN_; // EEMEN=1; prog.total_turns = program[temp_prog].e_total_turns; prog.stop1_turns = program[temp_prog].e_stop1_turns; prog.trvs = program[temp_prog].e_trvs; prog.offset = program[temp_prog].e_offset; prog.index = program[temp_prog].e_index; prog.stop2_turns= program[temp_prog].e_stop2_turns; prog.dir = program[temp_prog].e_dir; WMCON &= ~EEMEN_; // EEMEN=1; }
"Now what should be my approach? beacuse if I will go for byte by byte write then the code size will be too big." Use a pointer in a loop to copy the structure(s) byte by byte. You need to map in the EEPROM, wait for the ready bit, write a byte, wait for the ready bit etc. To read, all you need to do is map in the EEPROM, wait for the ready bit then do a structure assignment. This is based on being familiar with a similar but not identical Atmel part so check the datasheet for precise information.
