I have a struture which is correctly allocated at address 0x4000 (read from the M66 file). The DPP0 is used by Keil to point to the NDATA memory chunk: DPP0 = 1 so the pointer to my struture, when stored in a register is 0x0000!!!! Unfortunately, I check if this value is different from a NULL pointer. The generated assembly code is: CMP R15 #0 JMPR CC_Z, ..... where R15=0, which is the right value to point to 0x4000 with DPP0=1 and MUST not be interpreted as a NULL pointer! Is it a bug?? The memory configuration is 0->0x3999 of ROM 0x4000 -> 0x24000 RAM Near memory model: 32k RAM, 16K ROM
