Hi all, I'm new to 8051, have written this simple program, please see if this is correct #include <AT89S8252.h> void wait (void) { ; } void main( void ) { unsigned int i; P1 = 0; while(1) { P1=1; for (i=0;i<20000;i++) { wait(); } P1=0; } } After compiling I got this hex :0300000002001CDF :0C001C00787FE4F6D8FD75810702000330 :0100280022B5 :10000300C292D292E4FFFE1200280FBF00010EBE7F :090013004EF5BF20F2C29280E913 :00000001FF Unfortunately this is not working when I programmed it on AT89S8252. Please help me to figure out the problem. Thanks
You're being impossibly vague. How exactly did you deduce that the .hex file didn't work, as programmed into your chip? Did you run it in the uV2 integrated simulator first?
If you look at the port with a scope, I'm sure you'll see that it's working. The port is zero for a very-very short time. You might want to insert wait() in between p1=0 and p1=1. HTH Sam
As I told you I'm newbie, right now I don't know I to use simulator. So I tried programming AT89S8252 itself. I would appreciate if you please help me to figure out the problem.
As I told you I'm newbie, right now I don't know I to use simulator. So I tried programming AT89S8252 itself. I would appreciate if you please help me you are already helped: If you look at the port with a scope, I'm sure you'll see that it's working. The port is zero for a very-very short time. You might want to insert wait() in between p1=0 and p1=1. Erik
Ok fine, I some how managed to blink the LED. Now another problem, immediately after the reset it glows very brightly for a single time and after that it is so faint that it is hardly visible! What could be the problem?
Put a similar "for (i=0;i<20000;i++)" inside the wait function. Sam
"As I told you I'm newbie, right now I don't know I to use simulator." You need to start by reading the uVision Getting Started Guide, and working through the example projects in it. This will give you a proper introduction to the tools, how they work, and how to use them - rather than just jumping-in blindly at the deep end. (The uVision Getting Started Guide is available on the 'Books' tab in the 'Project' Window; The 'Books' window is also available via the 'Help' menu; failing all that, search for GS51.PDF in your Keil folder)
I'm totally stuck, my hardware is working fine. I verified it with this asm example http://www.iguanalabs.com/1stmicro.htm. It seems that there is some problem on software side, maybe I'm unable to configure it properly! I need your valuable help. Thanks again
I'm totally stuck, How aboiut showing your code after the suggestions have been implemented. Erik
