I have the follwing problem? I have just three files in my project. 1. main.c 2.I2c_sw.c 3.Startup.a51 I2c_sw.c file has few lines of assembly code. so I have checked "Generate Assmebler SRC File" & "Assemble SRC File" Options It worked fine. But If I were set the above options to main.c file the follwing error occured. *** WARNING L1: UNRESOLVED EXTERNAL SYMBOL SYMBOL: ?C_START MODULE: Startup.obj (?C_STARTUP) *** WARNING L2: REFERENCE MADE TO UNRESOLVED EXTERNAL SYMBOL: ?C_START MODULE: Startup.obj (?C_STARTUP) ADDRESS: 00A2H I am not able to find C_START function/ any such lable? And how "LJMP ?C_START" instruction in STARTUP.A51 jumps to main(). Kindly explain me the programme excution sequence clearly and how to clear the above error, more importantly why it happend?
Thank you Sarang Patki. I got it.
