Hello all, I was hopeing that somebody could help me out.. I have started into a new project development, and when entering the 'Debug Session' I do not see any peripherals under the 'Peripherals' tab. I used to with other projects. I am using a SiLabs C8051F016, which is shown to be on the 'supported' list. I am using the following versions: uVision2 V2.40a C Compiler: V7.20 CPU DLL: S8051.DLL V2.44 Dialog DLL: DCYG.DLL V2.41b Target DLL: SiC8051F.dll V1.5 any ideas why they would have 'dissapeared'?? I do use my emulator for most things, but I have some timing delay functions that I need to tweak in to an exact uS count. and that cant be done easily with the emulator. thanks for any suggestions. David
We have taken out the peripherals of the devices that are not 100% simulated. In this old version you might select the C8051F020 and you will see again the old peripheral list. However, the current release V7.50 fully simulates this device variant. Reinhard
