Hi, I found my bug, but I want to understand why the compiler did that! I use a fonction to clear bits: CLRBIT(BYTE, MASK); The following C code: CLRBIT(aBMCURegisters[REGADDRESS], I2C_SELECT_BIT | DDC_BYPASSN_BIT); Compile this ASM code: ANL aBMCURegisters+01H,#07FH Which is wrong because, the definition of bits are: #define DDC_BYPASSN_BIT bmBIT2 #define I2C_SELECT_BIT bmBIT7 It's like the compiler only check the first bit of the second argument! To compile a right code, I need to put the second argument between (), like this: CLRBIT(aBMCURegisters[REGADDRESS], (I2C_SELECT_BIT | DDC_BYPASSN_BIT)); Compile this ASM code: ANL aBMCURegisters+01H,#07BH Please note that the C code use only one line... (no return between args). Do you know why? Thanks, Denis.
You don't give us the definition of CLRBIT, but most likely you have a precedence problem in the macro definition. The fact that an extra level of parens fixes the problem makes me think this is likely. As a general rule, macros should always parenthesize their arguments in case an expression is passed in. For example, rather than #define min(a,b) (a < b) ? a : b write #define min(a,b) (((a) < (b)) ? (a) : (b))
You are right! Haaaa! Why I didn't see this... My definition was: #define CLRBIT(THE_BYTE, BITMSK) THE_BYTE &= ~BITMSK I changed for: #define CLRBIT(THE_BYTE, BITMSK) THE_BYTE &= ~(BITMSK) Thanks, Denis.
That's still not careful enough. The two most important rules for writing function-like macros are: *) put a pair of parentheses around every use of any of the arguments. *) put another pair of parentheses around the whole macro body This a basic FAQ-level C knowledge. You should be beyond that if you're going to write embedded C.
I agree with you, except that I wrote some code in the past with some micro devices and I never used macros... It's not a necessary knowledge when the compiler support inline function. I beleive that C51 should also support it! Do you?
when the compiler support inline function. I beleive that C51 should also support it! it does. That it does it in a crummy way (no debug of C source etc) is another story. Erik
"I beleive that C51 should also support it!" It's an ANSI compiler. Where does ANSI say anything about inline functions?
