How to read an assembler pointer in C (ARM)?
Hi all,
how can I get address (dOffset) of an assembler variable (T0TIMIIRQHandler) in C program?
asm startup.s -----------------
// Peripherals IRQ Handlers Address Table
PUBLIC T0TIMI_Addr
PUBLIC IRQ_Vectors
IRQ_Vectors:
T0TIMI_Addr: DD T0TIMIIRQHandler
FLASH_Addr:  DD FLASHIRQHandler
void EIC_Init(void)
extern u32 T0TIMI_Addr;
u32 dOffset=((u32)&T0TIMI_Addr); <<<<< link error here
The linker say:
ERROR L102 EXTERNAL ATTRIBUTE MISMATCH
SYMBOL T0TIMI_Addr
How can I do that?
I am using STR711 ARM with Keil IDE.
Thanks in advance!
Regards
Paul
  • "The linker say:
    ERROR L102 EXTERNAL ATTRIBUTE MISMATCH"
    So you need to make the attributes match!
    Basically, you need to ensure that the assembler definition and the 'C' declaration have precisely the same type.
    Ask yourself: what is the type of the symbols T0TIMI_Addr and FLASH_Addr defined in your assembler?
    And is this type the same as a u32 in 'C'...?
