Inline Assembler - error C195
I can't compile inline assembler code, which includes intruction
MOV [Rw+],[Rw]
Please see modified example from appl. note 172. Compiler returns warning C195: inline-asm: ambigous operand type, 'word' assumed on line labeled lM. I don't know why.
void copy (int near *pTab1, int near *pTab2, int N)
  __asm
  {                   ; open inline-assembly block
    mov   r7,pTab2
    mov   r3,N
    cmp   r3,#0
    jmp   cc_sle,stop ;
    shl   r3,#1       ; N * 2
    add   r3,r7       ; R3 := (N*2)+pTab2, end of table + 2
    mov   r4,#0x00    ; clear result
lM: mov   [r7+],[pTab1]
    ADD   pTab1,#2
    cmp   r7,r3       ; end of table ?
    jmp   cc_nz,lM    ; loop if not eot
stop:
  __asm { nop    ; single line assembly }
  __asm { nop    ; another nop          }
I can't compile some units from DSP Library produced by Infineon, that's my main problem.
I use C compiler v.5.05.
Thak you for advice
Pavel
