Hi everybody I am using ADuC7026 and i want to place some functions in RAM and want to call from it, is there any example or any process which i have to follow to get my answer.
Since you have not had the courtesy to select a toolset, so I will respond based on the guess that the device you use which I do not know is a '51 derivative as all ADuCs I know are. You need a negative or gate to convert the harvard architecture to VonNeumann. Erik
