I have file with many subroutines. How can I use this file in my project? I have problem that in output hex file are all subroutines (used and NOT USED) example:
main.c extern void Sub1(void); void main(void) { // some code Sub1(); // some code } subroutines.c void Sub1(void) { // some code } void Sub2(void) { // some code } /pre in output hex file Sub2 is included. How can I remove unused code from output
//void Sub2(void) //{ // some code //}
i think the answer will bve 1) split it in separate modules 2) put those modules in a library Erik
#idef INCLUDE_SUB2 void Sub2(void) { // some code } #endif
Library? Good idea. How can I make library?
"How can I make library?" http://www.keil.com/support/man/docs/lib51/
Oops, that should have been: http://www.keil.com/support/man/docs/liba/
